Ansys Learning Forum Forums Discuss Simulation Fluids “Input Geometry Parameters – BladeGen – Francis Turbine” Reply To: “Input Geometry Parameters – BladeGen – Francis Turbine”
rfblumen
The Deswirl Vane template in BladeGen can be used as a starting point for a Francis turbine runner design.  You can specify in the Initial Meridional Configuration Dialog window of the template the inlet radius and outlet hub and shroud radiialong with the z coordinates.
