Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Errors Running Ring Modulator Example on Cluster › Reply To: Errors Running Ring Modulator Example on Cluster
adevata
I believe the simulation completed successfully, the .log file output from the CHARGE simulator says that too. I'm not really sure what has changed, but now step 4 is running fine too. When I had sent my preset screenshot, those were without any modifications to the original preset. Do you have any pointers on how to recreate the original issue so that it can be effectively solved? Thanks!
- AD
