Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Structural Analysis of a Rocket Fairing › Reply To: Structural Analysis of a Rocket Fairing
Dennis Chen
You can also turn on the mesh worksheet.   An awesome recent update allow you to view which elements failed which criteria.   the mesh quality worksheet is under the mesh tab, and look at top right (you can also use the search function on top right corner of the GUI).   If this is indeed a memory issue, then reduce mesh sizing first and give that a try and then use the worksheet to selectively adjust your mesh setting to resolve the failed elements.
