Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Fluid Domain Mesh around Wind Turbine Blade › Reply To: Fluid Domain Mesh around Wind Turbine Blade
And the blade is definitely void? A relatively fine surface mesh should work well, but if it's too coarse it'll not handle the curvature well. You may need an even finer mesh to capture the blade profile.
1375939052's approach has merit, but may be less accurate.
