Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Fluid Domain Mesh around Wind Turbine Blade › Reply To: Fluid Domain Mesh around Wind Turbine Blade
December 6, 2024 at 2:34 pm
Is it possible to use a blade as a wall without thickness? If you really don't have a solution, give it a try.
You can, but that may or may not give the correct drag due to the profile. It's commonly used in mixing tanks where the blades are flat plates (Rushton Turbine).
