Ansys Learning Forum Forums Discuss Simulation Electronics Importing older model into 2024R2 Reply To: Importing older model into 2024R2
AncS
Hello Edson,
Thank you for reaching out to the Ansys Learning Forum, your patience on this issue is much appreciated.
Please note that in AEDT,starting from 2023R1, there is a change in geometry modelling kernel from ACIS to parasolid. That would be the reason for not being able to import the geometry of older model into AEDT 2024R2.
 However, you can try exporting the geometry as .step file and importing them back into the new version. This should help re-format the geometry code and fix most geometry issues, but you will have to re-assign the materials and excitations.
Regards
Anchal
