Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Analysis validation using actual values in axial fan rans simulation › Reply To: Analysis validation using actual values in axial fan rans simulation
December 5, 2024 at 4:43 pm
I calculate the air density according to the temperature and humidity measurements I took before the test and assign it to Fluent. I assign a slip condition to the walls to eliminate friction losses in the wall and tunnel material. I assign 0Pa guage pressure-inlet to Fluent for the inlet and the 0pa outlet. I assign the actual rpm value I read in the test to the mrf region I set in Fluent. I get mass flow rate and pressure at 480mm as output.
