Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Analysis validation using actual values in axial fan rans simulation › Reply To: Analysis validation using actual values in axial fan rans simulation
The wind tunnel is designed according to the AMCA-210-16 standards. The fan is installed at the inlet of the tunnel, and measurements are taken from the tunnel walls using multiple probes positioned at the 480 mm mark on the z-axis. The measurements are conducted at ambient atmospheric pressure. The fan operates at variable RPM, such as 3000 RPM. At the exit of the air tunnel, I use another fan to adjust the static pressure (for ex.50 Pa), bringing it to the desired level of 480 mm. This setup allows me to observe how the fan generates a flow rate under different pressure values and rotational speeds.
