Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Analysis validation using actual values in axial fan rans simulation › Reply To: Analysis validation using actual values in axial fan rans simulation
December 5, 2024 at 3:57 pm
I see. So what is the effect of the outlet diameter of the tube-fluid domain created in MRF-RANS fan simulations on the analysis? What would you suggest to me to make the ratio between this tunnel exit diameter and fan diameter? Does the growth of this diameter cause losses in the analysis? I am waiting for your suggestions, thank you.
