Ansys Learning Forum › Forums › Discuss Simulation › Fluids › finding minimum distance between walls in UDF › Reply To: finding minimum distance between walls in UDF
December 5, 2024 at 2:05 pm
I can only point you to the documentation for the coding element. Given PBCS is good for Mach 2-3 I don't know if you really need density based. The other option is not to look for wall separation but instead look at position: ie if the ground is at x=0 make sure the object can't get below x=0.5 for example.Â
