Ansys Learning Forum Forums Discuss Simulation Photonics 2D inverse design grating coupler Reply To: 2D inverse design grating coupler
rahul.sanghvi
Hi Anna,
Thanks for explaining. The first answer regarding sweep is clear.
Regarding the cluster, the given example describes about a sweep where the .fsp files are created, saved and then FDTD is performed. How can I run the file "pid_grating_coupler_2D_1etch.py" in the same way ?
It does not create any .fsp file but performs FDTD upto 100 iterations (or any user defined number) to optimise the grating structure. In this case, how can I perform this optimsation on HPC.
