Ansys Learning Forum Forums Discuss Simulation Fluids finding minimum distance between walls in UDF Reply To: finding minimum distance between walls in UDF
himanshujoshi
Thanks Rob for your comments. I am actually trying to build a contact detection model itself, as the in-built contact detection model has issues with density based explicit solver when used with explicit time integration scheme.
any leads to calculate minimum distance between the moving surfaces would help me get a step closer. Â
