Ansys Learning Forum Forums Discuss Simulation Fluids Unable to set mass-flow outlet while using DDPM Reply To: Unable to set mass-flow outlet while using DDPM
DDPM uses the Eulerian Multiphase model and that means no mass flow outlet. What level of volume loading have you got as DPM may be sufficient?
