Ansys Learning Forum › Forums › Discuss Simulation › Fluids › How to specify mass of solid particles in mixing tank simulation › Reply To: How to specify mass of solid particles in mixing tank simulation
December 5, 2024 at 11:32 am
Have a look at the Patch function once you've initialised, or initialise a volume fraction directly using Standard.Â
With 100nm you may also want to review the use of species as the particles will pretty much always follow the flow.Â
