Ansys Learning Forum Forums Discuss Simulation LS Dyna Workbench LS-Dyna ELFORM Reply To: Workbench LS-Dyna ELFORM
Jack.Vincent
Hi Armin,
When I follow your soloution above, I cannot select ‘Fully Integrate Shell Element’ the only option I am given for Formulation is ‘Program Controlled’. I am using 2023R2 if this makes any difference?
When defining the global mesh settings I am using Phyics Preference – Explicit and Element Order – Linear. Not sure if these settings need to be adjusted as well?
Thanks, Jack
