Ansys Learning Forum Forums Discuss Simulation General Mechanical Converting Honeycomb Unit Cells from Solid to Shell Elements in ANSYS Reply To: Converting Honeycomb Unit Cells from Solid to Shell Elements in ANSYS
Bahy209815
Dear Rohan,
I can't thank you enough for your support! I was able to follow your guide and successfully convert the HC unit cells to shell elements. I was just missing the options panel, and once I found it, everything worked perfectly. Your efforts are much appreciated.
Thanks again for your assistance
