Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Converting Honeycomb Unit Cells from Solid to Shell Elements in ANSYS › Reply To: Converting Honeycomb Unit Cells from Solid to Shell Elements in ANSYS
mohan.urs
Hey,
You can do that easily using spaceclaim or discovery ‘Midsurface tool’. Check out this link to know more
Midsurface Tool
Use the tool range option for efficiency and to convert your whole model to shell elements at once.
Creating Midsurface Faces Based on an Offset Range
Mohan Urs
