Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Ansys Thermal-Electric › Reply To: Ansys Thermal-Electric
Hi Chad,
I know you said each of your multiple input/output currents are "constant" but I just want to make sure... is the current AC or DC? If AC, you'd want, in general, to perform a harmonic response electromagnetic analysis to account for transient phenomena (skin & proximity effects, self and mutual inductance). This analysis type is not natively exposed in Mechanical but some relatively simple APDL command objects can be used to set this up in a Magnetostatic analysis system (details to follow if you're interested - let me know).Â
If DC, and your setup is in a steady state thermoelectric analysis system or (preferred in recent releases) a steady state coupled fields analysis system, then using the electric BC's such as those you described can be problematic. It sounds like you aren't constraining a VOLT DOF in your model. This is like performing a steady state thermal analysis without constraining the TEMP DOF anywhere, and hoping applied thermal fluxes are in perfect balance. Or like performing a static structural analysis with BCs allowing rigid body motion in some direction and hoping forces acting in opposite directions are in perfect balance. The system matrix in all these cases will very likely be ill-conditioned if not downright singular (unsolveable).Â
That being said, you could try turning off pivot checking (insert a command object under the analysis branch of the tree containing this: PIVCHECK,OFF). This might get you past the errors you're seeing.
If that doesn't help and you're APDL-savvy, you might try coding up a command object that adds independent current source circuit elements, each coupled to one of the faces where you want current added/removed:
Mind you, I just now thought of this and have never tried it before, so I'm not 100% certain it'd work. My hunch is that it will work (I do have a lot of experience using these element types). This should allow you to fix VOLT DOFs in the model.
Best,
Bill
