Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Errors Running Ring Modulator Example on Cluster › Reply To: Errors Running Ring Modulator Example on Cluster
Lito
Can you run simulation (waveguide_modulator.ldev) using these settings?  If you can run using "Local Computer" - the issue is with the MPI installation.
