Ansys Learning Forum Forums Discuss Simulation Fluids Rocky adhesion model with electrostatic module Reply To: Rocky adhesion model with electrostatic module
Lucas Bertollo Baggio
Hey seijieng,
The electrostatic module does override the adhesive model selection, so the only way you would be able to do this is by reimplementing the built-in model in a module combining with the electrostatic one.
Unfortunately, it is not possible to access the built-in models source codes, so there is not a way to use the models together.
Best regards,
Lucas
