Ansys Learning Forum Forums Discuss Simulation Fluids Air Heat Transfer Coefficient – SteadyStateThermal Simulation – ANSYS Mechanical Reply To: Air Heat Transfer Coefficient – SteadyStateThermal Simulation – ANSYS Mechanical
dlooman
That's a pretty big difference between the measured temperature of 130 degC and the FEA temperature of 250 degC!  Is it possible you have a conductive heat path you're not modeling?
