Ansys Learning Forum Forums Discuss Simulation Fluids Setting the Courant Number Reply To: Setting the Courant Number
Nick Fan
Thank you for your reply, Rob. To clarify, should I first calculate the time step size that satisfies my desired Courant number based on my settings?  Is it recommended to use a value larger than this calculated time step size as my "maximum time step size"?
