Ansys Learning Forum › Forums › Discuss Simulation › Embedded Software › SCADE Replaces Values with Null in Textual Expressions Causing Check Failure › Reply To: SCADE Replaces Values with Null in Textual Expressions Causing Check Failure
Benjamin Descorps
This is a limitation of SCADE 2023 R1 with use of textual expression. Literal values used in operator call within textual expression are incorrectly managed.
In 2023 R1, the solution is to rather use the graphical form:
The limitation has been removed since SCADE 2023 R2.
Benjamin
