Ansys Learning Forum Forums Discuss Simulation Optics Assistance Needed for Wavelength Adjustment in Optical Ring Modulator Simulation Reply To: Assistance Needed for Wavelength Adjustment in Optical Ring Modulator Simulation
abhishek_2311ee20
Dear Ansys Support Team,
Thank you for the detailed explanation and the helpful links. I will follow the steps you’ve outlined to re-run the simulations at 1550 nm and generate the "neff_vs_voltage.txt" file. Once that is done, I will proceed with the reduced-order model as you suggested.
However, I am not very familiar with designing circuits involving photonic devices. Could I kindly request the Ansys team to assist with designing a circuit that uses the ring modulator for light modulation? Specifically, I need help incorporating a voltage waveform from a PWL source file to drive the modulator.
Your guidance or a ready example for this would be immensely helpful. Please let me know if this is possible.
Best regards,
Abhishek Kumar Anand
MTech Student, Communication Systems and Signal Processing
IIT Patna
abhishek12.09anand@gmail.com
