Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Errors Running Ring Modulator Example on Cluster › Reply To: Errors Running Ring Modulator Example on Cluster
December 4, 2024 at 3:14 am
Hi Lito,
Thanks again for your reply! Again, in order, here are my responses:
- I'm using 1 node, 1 core, and 1 CPU. On that, I've requested 128 GB RAM.
- The attached pictures below show my resource and advance resource configurations.
- I believe my default is to only run on one node using the "Local Computer" preset. Could you confirm that is the case with my images?
Let me know if there's anything else I can provide. Thank you!
- AD
