Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Help on running inverse design CWDM 3D topology optmization › Reply To: Help on running inverse design CWDM 3D topology optmization
anna.wirth-singh
Hi Wangning,
Thanks, and good luck with your troubleshooting. Since you are using a current version of Lumerical, you should have the most up to date files for lumopt. I still suspect that this particular error has to do with the API connection.
Best,
Anna
