Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › ANSYS 2024R2 Installation on VDI › Reply To: ANSYS 2024R2 Installation on VDI
George Karnos
Are you stating that Roaming profiles do not exist?
Or, are they UNC?
If UNC, you can remap the c:\users\username\appdata\roaming folder to the server, which is supported and documented by Microsoft. The local appdata folders stay on the individual computers.  Workbench has issues with the UNC Path for Roaming appdata.
