Ansys Learning Forum Forums Discuss Simulation LS Dyna Problem with rubber when solving in LS-Dyna ACT WB Reply To: Problem with rubber when solving in LS-Dyna ACT WB
Ram Gopisetti
I suggest adding some cylindrical rigid walls around the rubber to confine it. Set some penalty factors to reduce contact penetration and try defining contact rather than relying on single surface contact as it's not robust.
Cheers, Ram
