Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › Workbench LS-Dyna droptest tutorials › Reply To: Workbench LS-Dyna droptest tutorials
armin.abedini
Hi Douk,
If you have already completed the Workbench LS-DYNA Getting Started course on the Ansys Learning Hub, there is another course focused on the drop tests using Workbench LS-DYNA that you may find helpful: Drop Test Simulation Using Ansys Workbench LS-DYNA - Ansys Learning Hub
As a general suggestion, besides avoiding initial penetration that you mentioned, try to reduce the use of Body Interactions and instead use contact pairs scoped to specific surfaces of the parts if you know how the interactions would occur. This will also reduce computational time.
