Ansys Learning Forum Forums Discuss Simulation General Mechanical Face-by-Face contacts Vs. Multiple Face Contacts Reply To: Face-by-Face contacts Vs. Multiple Face Contacts
Gary_S
I can't say there will be an accuracy issue with a few "massively scoped" contact pairs, however having a greater number of discreet contact pairs may be a bit more efficient for the solver.
Discrete contact pairs also allow you to confirm (via Contact Trackers) that each contact pair is behaving as expected and transferring load.
For : Why does automatic constraint creation tool only allow you to use BODIES in the named selections and not SURFACES!?!?!?!
  The idea is to leverage the auto-detection as much as possible so as to minimize or eliminate having to manually select faces.
 The Named Selection Bodies restrictons is so that you could have auto-detection groups each with unique criteria for the body types and interfaces.
 Example:
