Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Couple-field harmonic Analysis for piezoceramic sensor (PZT patch) › Reply To: Couple-field harmonic Analysis for piezoceramic sensor (PZT patch)
dlooman
Yes, you don't need to couple volt.  You can just specify the voltage on the faces without coupling it.  Usually coupling is used for postprocessing purposes, but it's totally optional.
