Ansys Learning Forum Forums Discuss Simulation Fluids Not being able to replicate paper simulations Reply To: Not being able to replicate paper simulations
Ren
The 2d model has a 1m depth. So you cannot use the same mass flow rate because the cross-sectional area is very different. You can try a velocity-inlet boundary and use a velocity same as that in the 2d-axisymmetry model.
