Ansys Learning Forum Forums Discuss Simulation LS Dyna Workbench LS-Dyna – Bodie penetrations during droptest Reply To: Workbench LS-Dyna – Bodie penetrations during droptest
douk.van.werven
Hi Nanda, thank you for your input. I use the following way of working (in line with the droptest tutorial I followed).
For interactions between the parts that collide with each other, I use the body interactions scoped to all bodies. When parts are bonded, I add a bonded contact to them. to prevent parts from going trough the floor, I also added a seperate contact propertie between them and the floor.
Is this correct way of working, or should I not use body interactions at all?
