Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › “flex net licensing error -5 147” (2024 R2) › Reply To: “flex net licensing error -5 147” (2024 R2)
December 2, 2024 at 8:44 am
Check if you have there is a proper connection between server and client machine, launch Ansys Licensing Settings vxx from start menu> verify the servername and port no.> hit on test, check if green check mark appear> save it> click on "feature in use tab"> verfiy if all increments are visible.
Check on server end if license server management services are ruuning.
