Ansys Learning Forum Forums Installation and Licensing Ansys Products Script Error 800a000d in meshing Reply To: Script Error 800a000d in meshing
saburalikhan333
Yes, as of now Windows 11 24H2 update is not supported by Ansys. So I fixed the Scrip Error Type Mismatch 800a000d issue by reinstallig 23H2 update on my computer.
To do so open SETTINGS in your PC/laptop then go to SYSTEM then scroll down to RECOVERY. Here you have to choose GO BACK option. Your device will go back to 23H2 version. It will take roughly 30 to 45 minutes. And dont worry non of your files or any data will be lost. Then you can use Ansys as normal. Based on what I’ve read, in Jan 2025 24H2 will be supported…so maybe pause your updates till the time, as Windows will automatically update outside active hours.
Thank You!!!
