Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Couple-field harmonic Analysis for piezoceramic sensor (PZT patch) › Reply To: Couple-field harmonic Analysis for piezoceramic sensor (PZT patch)
November 30, 2024 at 5:10 pm
The set up you describe with coupling the top and bottom faces and setting one to 0 volt (ground) and the other to 1 volt seems correct. It's not possible to read the error message. Could you provide the text of the message? Â
