Ansys Learning Forum Forums Discuss Simulation Fluids Tracer Mixing In Stirred Tank (Passive Scalar Transport) Reply To: Tracer Mixing In Stirred Tank (Passive Scalar Transport)
SR786
Thank you for your reply, I patched a small amount of tracer (24 cells) into a ~1.5 million cell domain. For the experiment a small volume (2 mL) of tracer was injected into a volume of water. The tank volume is 5.3 L and is half filled with water (2.65 L) which is what I am simulating in this run (upto the liquid height, flat surface). Do I need to patch more cells into the computational domain?
Also these are the mass fraction contours for standard k-epsilon & SST k-omega with curvature correction. As the tank is unbaffled, there should be strongly swirling flow with tangential velocity dominating. The dispersion predicted by the SST k-omega with curvature correction doesn't look realistic.
Standard K-Epsilon
SST K-Omega With Curvature Correction:
