Ansys Learning Forum Forums Discuss Simulation Photonics How can I extract sweep parameters and include them in the sweep results? Reply To: How can I extract sweep parameters and include them in the sweep results?
Kirill
Hello Subscriber,
This is not the typical workflow for a parameter sweep. Usually, you would obtain results from monitors or solvers during the sweep.
As a workaround, you can define a new variable as the result of the "model" object, assign it the desired value from the script, and then include it in the sweep results.
Best regards,
Kirill
