Ansys Learning Forum Forums Discuss Simulation Fluids Total pressure data of the simulation is not correct. Reply To: Total pressure data of the simulation is not correct.
Essence
If you observe the published graph data of pressure which has pressure decay characteristics, please see that it has been non-dimensionalized. That is, it has Y axis of Pt/Po and not just the Pt as seen in the Fluent graph which is in Pascals. I don't know what is at the X axis in published data, since the lower part of the image been cut off a bit. In published data, it is intervals of 5 units whereas in Fluent, it is 0.1 m interval. Isn't it?
