Ansys Learning Forum Forums Discuss Simulation Fluids Total pressure data of the simulation is not correct. Reply To: Total pressure data of the simulation is not correct.
am.23me1105
Respected Sir,
I am very much thankful to you for your kind valuable suggestion.
I will do a simulation with Two Boundary condition using Pressure outlet in place of pressure far field and Standard initialization then I'll make you updated.
Expected value for pressure is 2.5 bar is okay but concern is with flat line plot of total pressure in near field region, whether suppose to have rapid oscillation in near field region. From the published data I have attached earlier, you can see the pressure decay characteristics.
Again I am very much thankful to you.
