Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Total pressure data of the simulation is not correct. › Reply To: Total pressure data of the simulation is not correct.
November 28, 2024 at 2:27 pm
I see. Why are you using three BCs: pressure inlet, pressure farfield and pressure outlet? I believe you need to use only two of them. And use Standard intialization instead of hybrid for FMG initialization. I see the maximum Pt is 2.5 bar. What is the expected value?
