Ansys Learning Forum Forums Discuss Simulation Photonics Edge Coupler EME Example Issue Reply To: Edge Coupler EME Example Issue
Shangxuan Yu
Hi Kirill,
Thanks for getting back to me!
  1. I am using Lumerical 2024R2
  2. I got following error:Error found
I also tried to correct the code and get it passed the test by changing line 158 and 159 into:
set("set maximum mesh step", True)
set("dz", fine_dx)
and I tried rerun the propagation sweep and it seems work and the results match the example page.
However, I don't understand the reason the results looks strange without this modification? Could you elaborate on it?
