Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Total pressure data of the simulation is not correct. › Reply To: Total pressure data of the simulation is not correct.
November 27, 2024 at 3:55 pm
Respected sir,
The attached results and plots are STEADY state results, but I have run a Transient simulation which is not converging.
The transient simulation is not yet complete, but the results and total pressure plot look like they follow the same pattern up to the point simulated so far.
Total pressure contour of STEADY case attached herewith.
Thanking you sir.
