Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Assistance required for Air and Particle flow simulation through pipe › Reply To: Assistance required for Air and Particle flow simulation through pipe
November 27, 2024 at 11:30 am
I have set the following parameters for my simulation in ANSYS Fluent:
- Type: Pressure-based
- Velocity Formulation: Absolute
- Time: Steady
- Multiphase: Eulerian
- Viscous Model: k-omega, mixture
- Discrete Phase: ON
- Injection Type: Surface
- Particle Type: Inert
- Material: PVC powder (560 kg/m3)
- Diameter Distribution: Rosin-Rammler
- Discrete Phase: Particle
- Particle Velocity Magnitude: 16 m/s
- Total Flow Rate: 0.3 kg/s
- Min Particle Diameter: 0.000063 m
- Max Particle Diameter: 0.00025 m
- Mean Diameter: 0.0001 m
- Spread Parameter: 1.5
- Number of Diameters: 10
- Drag Law: Wen-Yu
- Inlet Boundary Condition: Velocity Inlet (20 m/s air)
- Outlet Boundary Condition: Pressure Outlet
- Initialization: Hybrid
- Calculation Iterations: 200
- Pipe Length: 32 to 35 m approx.
Can you confirm if these settings are appropriate for my particle and air flow simulation (fluid fluent)?
Training tutorials are a good option, but I need to resolve this issue urgently.
Please let me know as soon as possible. Your guidance is crucial for me as I cannot proceed further with my simulation without it.
Thank you.
