Ansys Learning Forum Forums Discuss Simulation General Mechanical Self-made car jack – static structural analysis Reply To: Self-made car jack – static structural analysis
Erik Kostson
Hi
Please do as below and follow it in detail:
  • Remove the force you applied (delete the force)
  • Add a displacement at the force location/face and push it down in y say by 0.0005 m (fix Z=X= 0 m).
  • Look at the reaction at this displacement to get the force applied due to displacement. To do that : Drag and drop the applied displacement to the solution/results in the tree (see here:
    The displacement is needed since the model might not be stable (run a modal analysis and look for modes with freq.~ 0 Hz which are rigid body modes and show any instability).
