Ansys Learning Forum Forums Discuss Simulation Photonics Edge Coupler EME Example Issue Reply To: Edge Coupler EME Example Issue
Kirill
Hello Shangxuan,
Apologies for the delayed response. The issue appears to be more complex than I initially anticipated. Could you please provide the following details:
1. Which version of Lumerical are you using?
2. Perform the following steps:
  o   Navigate to Object Tree > Taper > Right-click > Edit Object > Setup > Script.
  o   Click the Test button.
    What output do you see in the Setup Script Output field below?
Looking forward to your response.
Best regards,
Kirill
