Ansys Learning Forum › Forums › Discuss Simulation › Fluids › “heat of reaction” physical meaning › Reply To: “heat of reaction” physical meaning
ll00023
I found a source of the heat-of-reaction dimension.
So the heat of reaction variable does show the result based on volume (W/m3). Is this an inconsistency?
since I need to eliminate mesh's impact on the result, is mesh independent test enough for me to say : heat of reaction is not affected by mesh size, just like temperature?
or how to eliminate it in other ways?
you hit the point: the distinction between experimental data and Fluent results.
heat of reaction is Fluent results; why Fluent does not include the variables for experimental data directly?
I need to study the concepts of reaction and heat release further to understand you better.
Thank you.
