Ansys Learning Forum › Forums › Discuss Simulation › Fluids › liquid water evaporated into air › Reply To: liquid water evaporated into air
November 26, 2024 at 6:03 pm
801842
The vapor density is 0.01284 kg/m^3 corresponding to the temperature that I set up (15 ºC) and density of the phase wet air (air + water vapor) is calculated by the volumen-weight-mixing-law.
