Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Lift force computation › Reply To: Lift force computation
November 26, 2024 at 3:13 pm
You mention in 2DOF your object is translating in the same axis as your rotation. Is this correct?
I assume you are adding the falling velocity to the same flow you had in your 2DOF problem.
Can you show some contours of each solution?
