Ansys Learning Forum Forums Discuss Simulation General Mechanical Self-made car jack – static structural analysis Reply To: Self-made car jack – static structural analysis
kubatycjan
New warnings and errors showed up:
Error: An internal solution magnitude limit was exceeded. Please check your Environment for inappropriate load values or insufficient supports.  Please see the Troubleshooting section of the Help System for more information.
Error: An internal solution magnitude limit was exceeded. (Node Number 82894, Body Rail\Bryła1, DOF UY) Please check your Environment for inappropriate load values or insufficient supports.  You may select the offending object and/or geometry via RMB on this warning in the Messages window.  Please see the Troubleshooting section of the Help System for more information.
Warning 1 : Joints are being used in the current analysis with Large Deflection turned Off.  Thus, only linearized joint behavior will be considered.  If finite rotation and large deflection effects are to be considered, please turn on Large Deflection.
Warning 2:Two or more remote boundary conditions are sharing a common face, edge, or vertex.   This behavior can cause solver overconstraint and is not recommended, please check results carefully.  You may select the offending object and/or geometry via RMB on this warning in the Messages window.
